9 Essential Tools Every DIYer Should Know About
 Whether you are doing a small repair job around the house or building furniture, there are a few essential tools you must have. These tools are ideal for every skill level, and they are designed to make your work easier. Some of these essential tools can handle a wide range of repair jobs and woodworking jobs. And let’s be honest as a DIYer, you can never have too many tools, but there are a few essential tools that every DIYer must know about and have in their workshops.
The Essential Tools Every DIYer Must Know About
  1. Miter saw
A miter saw is the most frequently used power tool in any workshop. This saw can cut through several materials, including ceramic tiles and lumber. A miter saw is a unique tool that features a swing-arm with a blade that can pivot to the right or left and make an angled cut. This saw can make quick cuts for window casing, door frames, picture frames, and crown molding. Woodwork Nation advises that every DIYer must learn how to use a miter saw. After all, very few power saws are as versatile, affordable, or portable as a miter saw.
Photo by Annie Gray on Unsplash
  1. Cordless Drill
A cordless drill is a unique power tool that can handle all the drilling jobs in any construction and repair project. And compared to the wired drills, the cordless option offers greater maneuverability and convenience. The fact that a cordless drill is portable makes it ideal for handling jobs in tight spots. But you have to consider the cordless drill’s battery life when purchasing one.
  1. Hammer
A hammer is one of the most basic must-have tools that can be found in most homes. It is one of the most functional and accessible tools in any workshop. Most hammers have a head and a claw; therefore, you can use it to pry out a nail or drive one in. A hammer can be used in any job that needs a great whacking like banging a frame into place or breaking plaster.
  1. An Oscillating Tool
An oscillating tool, also known as a multi-tool, is the quintessential DIYer’s tool. This tool is designed to handle a wide range of functions such as sawing, sanding, scraping, grinding, and cutting, among others. A multi-tool is quite popular with serious DIYers, contractors, and carpenters. This tool can vibrate its blades over a narrow arc without spraying sawdust like a jigsaw or a reciprocating saw. And with the right accessories, a multi-tool can add efficiency to your job, making it possible for you to:
  • Cut off Bolts and Nails
  • Grind tile adhesive
  • Remove or clean grout
  • Trim wood flooring and baseboards
But, make sure you consider the oscillating angle when purchasing this tool. The oscillating angle is the distance a blade travels. Multi-tools with shorter strokes are relatively easy to control, and they leave smoother finishes. Multi-tools with great oscillating angles can cut at a very fast rate.
  1. Circular Saw
Circular saws are one of the most popular power tools in existence that can cut through lumber using a toothed blade. When used properly, a circular saw can provide clean cuts on a wide range of boards. This tool can cut through wet boards, dense boards, and pressure-treated wood. A circular saw is relatively easy to use, flexible, and affordable. A Circular saw is a powerful tool that requires some safety precautions when using it.
Photo by Greyson Joralemon on Unsplash
  1. Screwdrivers
A lot of things in your house, such as doorknobs, outlet covers, cabinet doors, and furniture, are attached using screws. Therefore, anytime you need to do a minor repair, you will have to remove the screws and put them back again using a screwdriver. In fact, some experts claim that screwdrivers are the most commonly used tools in their toolboxes. So, you can either purchase an 8-piece screwdriver set or a single multi-bit screwdriver. The single multi-bit screwdriver comes with one handle and an assortment of bits that can be swapped when needed.
  1. Locking Pliers
Locking pliers, also known as wrench pliers, locking pliers, or vise-grips, are useful tools that can be used as hand-held clamps or vice. Sometimes when doing some repair work, you need to clamp onto something so that you can turn or pull it. But, since your fingers are not strong enough, you will need a pair of pliers. A pair of pliers comes with metal teeth for gripping on one end and long handles to give you the needed leverage. Locking pliers are available in a wide range of designs, including C-clamp, flat, and even long-nose jaws. The standard design for adjustable pliers has straight serrated jaws.
  1. Hand Saw
A hand saw is a simple cutting tool that features a handle and a toothed cutting blade. A handsaw is a reliable tool that can come in handy when making quick cuts since it’s faster and easier to use. A hand saw is the best saw for building a treehouse since hauling a power saw up a ladder is not easy. There are different types of handsaws in the market, with the common ones being the basic hand saw, hack saw, and the Japanese pull saw.
  1. Staple gun
Staple guns are unique tools that can be used to fasten different types of materials when doing different maintenance and home construction jobs. This tool is quite common among carpenters, insulation installers, and roofing contractors. This tool comes in either electric or hand-powered models; however, the most common staple gun is powered by a spring.
Final Thoughts
At times it’s not easy to decide if you need to hire a contractor to handle some repair work or do it yourself, especially if you don’t have the right tools. However, doing it yourself has numerous benefits, with the main one being saving you some cash on landscaping, house maintenance, and home decoration. Instead of always hiring a professional to help you improve your home, why don’t you purchase the above tools and become a DIYer? And the good news is that these tools are affordable and very easy to use.
Comments
Popular posts from this blog
Lamp Design Project: Day 1
