New Easel Feature: Carving Time Estimation
Our amazing development team has created a new time estimation feature in Easel. Because in this busy world, we know your time is precious. And faster carves means more carves!
While designing in Easel, you can now get an estimate of your total carving time. The “Show Toolpaths” button previously found in the top right corner of the 3D design pane has been replaced by a “Simulate” button. When “Simulate” is clicked, Easel calculates and displays the estimated time and toolpath visualization.
Taking the time to adjust small settings can add up to a big impact. In the below project example, simply switching your bit from 1/8" to 1/4" saves over 30 minutes of carve time. Adjusting other settings like material thickness and cut depth also make a difference.
CAM programs, due to all of the different possible machine setups, aren’t known for giving the most accurate machining time estimates. With this new feature, we’ve worked hard behind the scenes to have Easel deliver an estimate that’s now reliable enough for us to share.
The above graph shows the results of experimenting with a couple different methods for estimating time, and comparing those with the actual carve time. We almost always underestimated the total, but for 95% of makers the estimate was within a few minutes.
Give it a try for yourself today and let us know your feedback. If you have any questions while designing, check out this helpful article from our awesome support team!
Comments
Popular posts from this blog
Lamp Design Project: Day 1
