Pumpkin Carving with Easel and Shapeoko
Shapeoko 2 owner Winston Moy made an awesome video of how to use your Shapeoko to carve a pumpkin using Easel, our web-based CAD + CAM + machine control software.
The key is to remove the wasteboard and prop the Shapeoko up on stilts, giving you enough clearance to carve into the pumpkin. I think the most clever part is using a big coffee can to hold the spherical-ish pumpkin. Standard clamps don't work so well on pumpkins, as you might expect. And major props for giving a great introduction to using Easel!
Check out Winston's YouTube channel for a bunch of other awesome CNC projects. Also check out our projects section for more Shapeoko project ideas that you can open directly in Easel.
Keep it spooky.
Comments
Popular posts from this blog
Lamp Design Project: Day 1
