Introducing Bamboo Plywood and Bamboo Projects!
We now carry beautiful Bamboo Plywood in 4 thicknesses: 1/8", 1/4", 3/8", and 3/4" and two sizes: 8″×12″ and 12″ × 12″.
The pictures do not do this material justice! It’s the most beautiful item we have in the warehouse with its natural rich color variations. The surface finish is smooth, and the material is very hard, similar to hardwoods such as Walnut or Oak.
The Bamboo Plywood can be cut with regular tools. If you are cutting with a table saw, you can tape the edges to prevent flaking or tearing. If you are fastening the bamboo, be sure to pre-drill any holes. Because it’s a plywood, it may split easily if you don’t pre-drill. Regular wood adhesives can be used as well. For a better adhesion, sand before applying glue.
The materials, files, and instructions to make these awesome projects by Samantha Alaimo are available by clicking the links below!
Artist Palette Cutting Board
Comments
