Laser Cut Projects: Buck Hook
Hello!  I've been working with Inventables to come out with a series of  laser cutter projects to show how fab lab processes can be used to take a boring product that you might find at the store and crete a version with a bit of design. We invite you to join in our efforts in creating thoughtful and innovative products! The second project in this design series is the Buck Hook.
The Buck Hook is made with with laser cut acrylic that has been heat bent. Heat bending is a great way to add dimension to your laser cut designs.
Before heat bending                          After heat bending
Thanks for checking this project out! Tell us what you think about what we're making with the materials in the Inventables store. More projects to come!
Good designing!
Samantha
Comments
Anonymous said…
Very nice. Which laser machine did you use?
I recently found some nice laser cut wood. Check it out: http://www.pbase.com/troteclaserinc/examples_of_laser_cut_wood
Unknown said…
Wow! This could be one particular of the most helpful blogs We’ve ever arrive across on this subject. Basically Excellent. I’m also an expert in this topic therefore I can understand your effort.
Laser Cut Designs
Popular posts from this blog
Lamp Design Project: Day 1
