Thermally Conductive Plastic compounds
If you are working on sensitive electronic components you might consider using a thermally conductive plastic compounds to transfer heat away. High heat levels can often either disable or destroy an electronic component. When used properly a thermally conductive plastic part can be used to minimize the number of parts in an assembly and reduce the entire weight of the assembly. Unlike metal, thermally conductive plastic parts can be processed with injection molding or extruding into sheet or tape form.
Comments
Popular posts from this blog
Lamp Design Project: Day 1
